bradness
Hi guys (and girls?). I'm a Contour SVT owner working on a Fox body Mustang with a bolt on rr disc brake kit from Ford Performance. I'm trying to get a handle on replacement pads and discs and I'm dealing with old parts/part no.'s.
I have an old Ford Performancee Parts catalogue which identifies the rear disc pads as being the same on 89-92 SHO, 87&88 T-Bird Turbo coupe and the 89-92 T-Bird SC. Now I know that the SHO and the Super Coupe used 5 bolt wheel/disc pattern which I'm assuming is Fords standard 5 on 4.5", but the Turbo coupe & Mustang used a 4 bolt pattern.
Can anyone confirm the OD of the discs and the bolt pattern too? I'm converting to 5 bolt axles so I need that info. as well. Believe my brake kit uses parts from an 87/88 Turbo coupe.
Thanks!
Thanks!
