new here
travis bowman
SLO SHO 182
Hello everyone. This is Tori aka SLO SHO 182. Ive had my 2nd gen sho since feb 2016. she is a 92 green and was built in 91. Bought her for $1950 with 109k miles on the odometer. When I first got her I did ngk platinum plugs and taylor thunderbolt wires. Now with a new valeo clutch, findanza flywheel, new sho source axles at 141k and just did the wheel bearing. has dynomax mufflers. Swapped 93 console and wheel over. Has 16x8 roh snypers. Yakima q tower roof rack and 3rd gen Taurus mud flaps that I found nos on amazon. I have made a custom projector setup from an old setup from my brothers 02 gtp. Morimoto mini 6 projectors with morimoto 6000k hids. Car has almost no rust. Sadly was a salvage title from hail damage and will eventually get fixed. 17952026 10211588459520832 1295979064248956408 n 18447356 10211825375323579 994055844165152762 n 18765937 10211962238465072 6046443292506128243 n 18740365 10211962238305068 9062407929293275244 n 18945121 10212023644280179 1800922513 n 18944758 10212023645080199 2032893876 n 18985231 10212023645040198 45888047 n
zoomlater
Seattle, WA
Welcome! I daily drive an early 92 SHO as well
Where did you get your intake set up, I don't recall seeing one like that
travis bowman
SLO SHO 182
Its the stock setup on a 98-00 svt contour. I used its maf housing with my new maf sensor. This is probably the 3rd or 4th air intake setup. My custom cai setups kept sucking water. I'm hoping the walbro 516-1 fixes my issue with my car choking itself at low rpms.
travis bowman
SLO SHO 182
maf housing and air box is csvt. maf sensor is a new oem hitachi replacement I bought off rockauto. you probably have seen my sho on facebook. I'm in gen 1 2 and in 123 sho only group.
sperold
Last to Know
Where is the hail damage?
Is that a spoiler on the trunk lid?
Very nice all around.
Did the clock spring and all the other associated parts swap over without much effort, when you swapped the steering wheels.
Have you adjusted to the light flyweel.
People will mistake you for the police with your roof rack.
travis bowman
SLO SHO 182
Hail damage is on roof its pretty bad. Yes a spoiler on the trunk. I didn't have to remove the clock spring I just swapped over the pigtail that needed to be used. Flywheel was installed by a shop so hope they did. I will take a pic and show you it.
sperold
Last to Know
The flywheel comment concerns how the car launches from a stop. It takes a little more effort to get the car to pull away nicely, and it is easier to stall. But it makes the car more lively, as it revs easily.
Good information on the clockspring, very often things are not that easy when you go from year to year.
As a rule, the 92s did not get made with a trunk lid spoiler.
The black interior was only available in 92 and 93 for these second generation cars, so they are somewhat rare now, and a lot of peoples first choice.
travis bowman
SLO SHO 182
when I had flywheel put in with a new valeo clutch and sho source axles and every time I go to take off with any acceleration. I hear a pop noise on driver side and it feels as something wasn't done right. I got trunk off a clean 93 green with mocha interior off a yard car. doing a rear window delete with lots of parts off another 93 that was white with black interior. nearly full interior gut along with dynomaxx cat back I grabbed.
