New Guy
EVIL SHO
ILLINOIS
The Super Chips tuner is just a flash tuner that sets up generic tuning perimeters as a whole. A dedicated tune from a reputable tuner will not only tailor a tune for your specific set up and fuel, but it will also yield more power safely.
Take a gander at the first couple of pages in this thread for more information.
Good morning
so I looked over the car last night it doesn't have the pp setup.
can I just unplug the monitor that is mounted to the windshield
will that make the car go back to normal stock mode.
also I really only drive it on the weekends. not a daily driver.
Good morning
I would look into the device directions honestly. You may have to revert back to stock and actually remove the program/tune.
EVIL SHO
ILLINOIS
Good morning
ok thanks
EVIL SHO
ILLINOIS
so I have a 2017 sho installed gear head intercooler and tuner 3 map sensor runs great had dyno test done happy with results
but when I put it in sport mode and jump on it the engine light comes on I lose power then I back off and engine light stops flashing
it seems fine then I check engine codes found none. now in normal drive mode I never had a problem maybe possible injectors.
the new plugs from gear head were gap at 26 or maybe stock fuel pump causing problem. Hmmmmm not sure what my next move is.
EVIL SHO
ILLINOIS
need a little help
kryptto
South East, Florida
who did your tune? i know AJP uses Sport mode for dyno simulation. Assuming your a PP package, are you in park putting your foot on the brake and then holding the TC button till it flashed in the dash and turns off?
EVIL SHO
ILLINOIS
URW AUTOMOTIVE
crystal lake Illinois the specialize in turbo charge cars. no the engine light goes off on its own sorry I'll type slower fat fingers
EVIL SHO
ILLINOIS
they did dyno test in sport mode and I'm assume they took it off when testing. when using sport mode do I have to turn t/c off.
kryptto
South East, Florida
you have to manually disable tc each time I dont think anyone has found a way to disable it in programming. that said talk to the shop who tuned it, I dont know what they did to your sport mode, but my AJP tuned vehicle I never use sport.
markmoomnu
