New Guy Needs Help With Code Question
baldguy
Bristol, New Hampshire
I have a 98 and have put on a magnaflow y pipe PITA
all new spark plugs and did the brakes and i have the ABS light on still
I have had code P0303 and swaped #7 plug and coil with #3
still get the code also P1744 and P0610 I use a scan Gauge II for codes
after replacing the spark plugs cruise control does not work
it was working before i did the plugs
issues I have is the SES light would flash and then set the codes
and be on permanetly until it was reset
now all 3 codes come up at once after they are reset and the
SES light does not flash it just comes on solid I do not know if this means anything
I have also had codes P3128 and C0010 do not know what they were and have not seen them recently just the other 3
any help and suggestions would be appreciated
Thanks
BaldGuy
E1 v2
crash tested
holiday inn
Have you got an aftermarket chip/program on this car? Those are some bizarre 'p' codes.
P0303 is common - #3 coil - cylinder misfire.
P1744 is common, but bad news. Tranny is in trouble.
The other ones are head scratchers.
Try taking off the battery positive cable and stepping on the brake 3 or 4 times. Put it back, drive around for a while, when your codes reset, go to an AutoZone and have THEM read the codes, they'll do it for free.
Then repost what the AZ codes came up as and maybe we'll go from there.
bacernate
97 MONEY PIT
Denver, Colorado
I looked in alldata and cannot find c0010,p3128,po610. Try clearing them and see what comes back. I can tell you c series codes are Antilock brake codes. As far as I know p codes don't go higher than 2000 series not into the 3000 range.
P1744 is bad news torque converter not locking up, internal trans problem!!!
baldguy
any ideas on the cruise control problem worked when i got the car
stoped working after the repairs and i do not get the Cruise light on the dash
Thanks
BaldGuy
SHOMEX
Taylorsville, Utah
Check to see if you leave something deconected while doing the spark plugs; to me its sound completely strange theat you got to many codes right after the repairs. :confused:
Good luck finding your problem though.
