JohnW63
I believe my '95 ATX has had a brake problem since day one. The REAR brakes wear out so much faster than the fronts do. I bought the car , from my in-laws, at about 36K miles, and I don't think they had the brakes serviced during that period. Some time after I bought it, I heard the tell tale sound of metal on metal, ( Why doesn't this car have a mechanism to alert you to a worn brakes condition !? ). I took it to the dealer since I had an extended warranty. They found that the right rear rotor was trashed and the left rear was starting to scratch. The fronts were fine. When I asked to see the front pads, they had convienently thrown them away, so I don't know how far they had worn. Less than a year later, I thought I heard it again. I took the car to a third pary garage and they said the right rear caliper was hanging up. I took it back to the dealer and they supposedly cleaned and lubed the caliper and it was fine. SOme time last year, my father in-law replaced all the pads again, sine they sounded like they were squeeling. The rears would squeak a LOT after that job, but my father-in-law couldn't hear it. ( He's not as young as he used to be. ) I took the rotors off, had them all turned to be sure they weren't off, replaced all the pads with AutoZone lifetime stuff, lubed all the caliper pins , adjusted the parking brake, and still couldn't keep the rear pads from squeaking, especailly when I would turn corners. The sqeaks slowly went away, but...I was checking the air in my tires, yesterday, and saw the rear rotors were scored quite noticably.
Is there a proportioning valve that could be bad ?
Is there a way to check the pressure at each wheel and see if it was off ?
I'm REALLY getting tired of this !!!
JohnW63
JohnW63
