jasenklems
I want to swap a 3.2l with a manual into my car it is not a ford..... Have some questions about upgrades....... I want to run the wesco12.5:1 pistons with the plus 40 cams and a stage 3 port job on the intake runners with the 40mm bbb and the 75mm maf and the oversized valves they are 36mm on the intake and 31mm on the exhaust also with the full lenght header and equal lenght high flow cated ypipe ...... so my question is will the 48lbs injectors over fuel the motor with a new high flow fpr kit......
