Need New Pads and Rotos for 2010 SHO
tambo79
Pittsburgh
I need new pads and rotors for my 2010 SHO.
I live in Pittsburgh so I deal with pretty much every weather imaginable and we are about to head into snow season here.
I really know ZERO about cars. I just want to get the best brake pads and rotors available for my car.
Any help would be awesome.
Thanks!
Does your SHO have the performance package? You can pull up the window sticker online to check. The only difference is brake pads, which should fit the non-PP SHO's as well if you want to upgrade.
For example, look under "optional equipment" in this example, you will see the items in the Perf Pkg listed:
http://www.inventory.ford.com/services/inventory/WindowSticker.pdf?vin=1FAHP2KT9EG102371
If the above link does not work, the one below might:
http://researchmaniacs.com/VIN-Number-Lookup/WindowSticker/Ford.html
It is a good time to upgrade to aftermarket pads, EBC being heavily favored.
If you want to do the whole setup, and don't mind drilled/slotted rotors, Power Stop is very budget-friendly, and great for DD SHO's. EBC has kits as well, worth looking into.
Top pad = non-PP, Bottom Pad = PP
Take the opportunity to a) flush & fill the brake fluid, b) grease the caliper bolts/slide pins, and c) optionally paint the calipers :D
The caliper piston in the rears has to be "unscrewed" to remove, it does not come straight out like the fronts do. Best to do it with a special tool, usually available for rent from chain auto stores.
No performance package on your SHO then.
PowerStop:
Z23 Evolution Sport Performance 1-Click Brake Kit
Front : K5507
Rear : K4744
Front & Rear : K5508
or the higher performance kit:
Z37 Top Cop Brake Kit
severe-duty/fleet pads with Drilled & Slotted Rotors
Front : K5507-37
Rear : K4744-37
Front & Rear : K5508-37​
EBC:
S4KF1297 - Front Brake Kit
Stage 4 Signature Front Vented Brake Kit by EBC®. Brake Kit Includes EBC Part Number Rotors: USR7510, Pads: DP31825C.
-OR-
S4KF1273 - Front Brake Kit
Stage 4 Signature Front Vented Brake Kit by EBC®. Brake Kit Includes EBC Part Number Rotors: USR7510, Pads: DP31767C
S4KR1204 - Rear Brake Kit
Stage 4 Signature Rear Solid Brake Kit by EBC®. Brake Kit Includes EBC Part Number Rotors: USR7280, Pads: DP31826C.
EBC's "Affordable" combo:
S20K1098 - Front and Rear Brake Kit
Stage 20 Front and Rear Front: Vented, Rear: Solid Brake Kit by EBC®. Brake Kit Includes EBC Part Number Rotors: RK7510, RK7280, Pads: UD1158, UD1377.​
southtxsho
mission tx
I bought the powerstop kit but what I am seeing here is that I got the pads for the PP. And my car is non PP. Could that cause an issue ?
Sent from my SM-N920T using Tapatalk
Power Stop doesn't list a PP kit as such. EBC does (pads), and the PP pads fit fine on the non-PP setup.
shobroooo
