Need Local help...
Tecchie
Marysville, Washington
I would like to know who is in or around the Everett/Seattle/Marysville area of Washington State... I can drive to you or pick you up, etc.. but would like some help with my SHO.. ANY help would be very appreciated...
My name is Brian, Cell is 425-328-9723 If I don't answer, please leave a message with name and #... thanks guys! everyone has been very helpful so far.. :D
Having issues with pretty much everything fuel related... pump is noisy and ECU test says secondary pump relay failed, running rich and too lean on one or both banks... etc...:omgsho::thankyou:
ml98188
Seattle
Brian,
Sounds like you're looking at a pump and a few relays. Pumps are a real PIA.
Not too much prof help I'd trust. I did find one guy in Kent.
Les at 212th Automotive is VERY good. Charges pretty good but well worth it in
the time one saves screwing around with these things.
He's an ex 25 yr line mechanic for Ford and did all the SHO and other Hi Performance
work for Bellevue for a number of years. Knows SHO's inside out.
FastAndFurious
Washington
I just searched what is wrong with secondary pump relay failed code, and it seems like the code comes up everytime you stall the car. For running rich and too lean, you should change o2 sensors if you haven't yet. I would change fuel pump and filter if I were you.
If you need any help, just call me up. I sent you pm, so you should check it.
