I just recently installed new Tokico's, and my biggest problem now is my is the popping/groaning I get when turning and I just recently discovered my right spring popped out of its lower mounting perch
because something up top is binding bad.
Here are the parts I replaced, of course the Tokico's, new strut bearings, police strut mounts, and washers/hardware, what I never replaced were the plates that have slots where the bearings tabs slide into.
Would that plate be causing my very bad binding problems now? Before I even did the Tokico's I had no binding problems or even noises just endlink issues, so the only thing I can blame this new problem is how I re-assembled the whole strut setup itself(improper placement of the two big washers?) or because I reused those plates the bearings sit on...??
