need help with codes,sputtering!
Cocoa,Florida
alright guys i need some help with some codes im getting
KOEO 49 and 59 no C/E light
car has a eratic idle sometimes,also after driving if i come to a stop
the car will sputter and stall out,also intermitent,but will refire with
no problem.Car has no power loss issues,runs very strong.
Has had recent 60K including CPS,plugs,wires,new DIS,and coil pack
also has had fuel pump replaced with Walbro 155 or 190,not to long ago,
just did filter today!
thanks for your help guys!!!!!!
Brian :corn:
Mike Kelly
Middleburg, Florida
codes
No suggestions for repairing, just explanations.
49 - Electronic Ignition - spout signal circuit problem Transmission 1/2 shift problem
59 - AXOD 4/3 circuit fault 3.0L SHO - Low speed fuel pump circuit problem Transmission 2/3 shift problem
SHO#7
Cincinnati
Help us out with the car. Is it a 91. As I can not see how your MTX would even have ATX codes.
Cocoa,Florida
yes my SHO is a 91,thus a MTX.Near stock
the # 49 code is the one that im worried about
i have no clue what it means?????
Lorenr
Vancouver,WA
Code 49
Had this in my files, I forgot where I got it.
Article Title: Trouble Code 49 Diagnosis
Contributed By: latechsho
Service Code 49 indicates the spark timing has defaulted to 10 degrees before top dead center. The SPOUT signal has a variable duty cycle with amplitude that varies from 0.4 volts to VBAT or ~12V. In the event of a SPOUT failure, the DIS module will generate a fixed dwell and constand spark angle based on CID and PIP signals (FMEM mode)
Possible causes:
-- Faulty DIS module
-- Faulty SPOUT circuit
Key off, wait 10 seconds.
Disconnect processor 60 pin connector. Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service if necessary.
With processor disconnected, disconnect DIS module (pins 1-6)
Using a voltmeter measure the resistance between Test Pin 36 at the ECU connector and the SPOUT circuit at the DIS module Vehicle harness connector.
If resistance is more than 5 ohms then you need to look for either a bad wire, or a bad connection at the in-line SPOUT connector. Clean up any corrosion at DIS module as well as SPOUT connector. Reconnect it all, and rerun the test.
If resistance is LESS than 5ohms Measure the resistance between ECU harness pin 36 and pins 16&40, also measure resistance between pin 36 and the positive battery post.
If all resistances are greater than 10,000 ohms than the EEC system checks out ok. Reconnect all components and test the DIS.
If all resistances are less than 10,000 ohms than there is a short circuit in the SPOUT circuit to either the power or ground.
ECU Pinout Diagram
note: Take special care not to damage the pins while testing. The official instruction call to use a breakout box for this procedure for that very purpose.
DIS Pinout Diagram
PIN 1 VBAT (BATTERY VOLTAGE)
PIN 2 CID
PIN 3 PIP OUT
PIN 4 PIP IN
PIN 5 SPOUT
PIN 6 DPI (DUAL PLUG INHIBIT)
PIN 7 IGN (MODULE GROUND)
PIN 8 COIL 3
PIN 9 COIL 4
PIN 10 COIL 2
PIN 11 COIL 1
PIN 12 IDM (IGNITION DIAGNOSTIC MODULE)
