Need Help With Code Meaning
rdavidrees
Oak Ridge,TN
Hi,
I have a '91 and my airbag light is flashing a 6 - 6 code with key on engine running. Can anyone tell me what might be causing this? According to the two digit codes info, it says 66 is : Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low - VAF MAF Transmission Oil Temperature (TOT) signal low (possibly grounded) - >Transmissions. This is not the check engine light flashing, it is the airbag light. As far as the CEL goes, on warm-up the CEL comes on after about 10 minutes of driving and then goes off at operating temp. I suspect it is my O2 sensors causing that. 152k on the original O2 sensors. Thanks in advance for your suggestions on how to determine my 6-6 code problem.
