Need help fixing Code 42 from the airbag
69crewcab
PA
Group
outthere someone had a code 42 airbag code and had step by step directions on how to fix???
Anyone???????????
69crewcab
PA
there was a post about to check the center sensor, if it wasnt that sensor it then
told you to check one of ther other side sensors?
Rockledge
Pluggin' away
Connecticut
AIRBAG DIAGNOSTIC TROUBLE CODE 42
Center Radiator Primary Crash Sensor Feed/Return Circuit Open
The voltage at Pin 18 (Circuit 619, PK/W) is approximately 10 volts (± 1 volt). Circuit 619 is connected to Circuit 625 (Y/LG) inside center radiator primary crash sensor. Therefore, the voltage at Pin 6 should be the same as the voltage at Pin 18. If the voltage at Pin 6 is lower than the voltage at Pin 18, the air bag diagnostic monitor will flash code 42.
Possible Causes - Low voltage on Pin 6 can be caused by:
1. An open circuit in the wiring harness in either Circuit 619 (PK/W) or Circuit 625 (Y/LG).
2. An open circuit inside the center radiator primary crash sensor across the PK/W and Y/LG wires.
You can refer to the following wiring diagram (it's from a '95 but should work for other years):
http://shoforum.com/diagrams/1995/9522.pdf
