Need Help fast about a recall
SHOMEUP
hanover park IL USA
Hey guys i really need the recall number to do my subframe bushings...my ford dealer constantly says there is no recall for my car for that- but if i give them the actual number than they might be able to do it- if neone of u know it plz let me know- thanx so much..
Gez89SHO
LEGO SHO
NE Philadelphia, PA
From the NHTSA site (www.nhtsa.dot.gov), 2 recall numbers are listed :93V106002, from 12/02/1993 and 98V323000, from 12/18/1998 .
Bizzy
These are the most serious ones I've found.
From 11/16/93
Recall 93V106002: Engine and Transmission Support
Number: NHTSA93V106002
From 11/23/94
Recall 94E036000: Monroe Shock Absorbers
Number: NHTSA94E036000
From 12/15/98
Recall 98V323000: Rear Lower Subframe Mount Plate Nut
Number: NHTSA98V323000
RStalveyARFF
too many shos
Georgetown, MA
Shomeup, maybe they're thinking you want new bushings, which in that case, they're telling the truth. The recall is to replace the rear bolts and nuts, and add reinforcing plate washers that are resistant to corrosion. If you by subframe bushings, they'll install the rears for you for free while they're going the recall, since they have to take them off anyway.
<small>[ May 01, 2002, 03:12 PM: Message edited by: SHO91MTX ]</small>
SHOMEUP
hanover park IL USA
Well i knew that but now i also found out that the recall has been done so now i have to change the bushings myself- i just was hoping like you said if the recall hasnt been done they could change my bushings for free but now i need to change them myself..oh well thanx though
