I doubt you are going to find a Gen1 in Quebec, and you will be hard pressed to locate a Gen2 that is not just a parts car.
Gen1s are more agressive looking, and I do prefer the seating design.
Gen2s are more luxurious and detailed, and the dash looks more modern (I am really tired of trying to find the window control switch at night in a Gen1, as they do not light up).
I have both, and they both have their appeal. One is not head and shoulders above the other.
If you want an automatic, stick to 94 - 95 and check the automatic out carefully as they do not last long in the hands of the wrong person; and you will need 2 -3K$ when it goes. You will need 1K$ when your Throw Out Bearing goes on you standard trans model.
In the beginning, pay a little more for a good one, because a fixer-upper will be more expensive in the end.
Good luck on the search, I am in Montreal a lot, and can help if needed when it comes decision time. There are 3 or 4 members from Quebec on here; and within easy driving distance, you have ShoNut Performance that you see advertised at the top of the page.
