N/a Dyno 318 H/p 279 Ft/torque
jedhead
westminster,ca
I spent alot of time talking with Vadim about cams torque curves, and displacement. One of the things that Vadim found out between the stage 1 and stage 2 cammed cars is that although the stage 2 cams had more peak hp over the stage 1 equipped car, the stage 1 car would beat the stage 2 car in a drag race. Where the stage 2 cammed car shine was on the road course where the engine could be kept in its narrower power band. This is reason I used to get Stage 1 cams instead of Stage 2, +20 or +40 cams. I wanted to maximize the area under the torque curve. When I start my 3.6l stroker motor I may go a stage 2 cams to take advantage of the greater displacement.
Bob
jayparot
NOS SHO
connecticut
hey guys this is my 3 dynos since i purchase this 95 green MTX sho the highest one is with a 100shot of NOS wet KIT direct port , the red one is when i got my car 184hp then mods Ypipe , full exaust Dynomax , nology wires and accell coil and new spark plugs k&n filter 199hp then 100shot NOS 260.9 and 295tq
SASHO91
Zoom Zoom
San Antonio,TX
AND??????
:shrug:
what does that have to do with this thread?????
egroce11
Taylorsville, Ut.
AutoSHO said:
Ernie - Let me know when you are headed to the dyno again. I've still got friends out in SLC and I'd love to come out and check out the car.
Chris (previously with the white 92, I met you at Modern Garage a few years ago)
I've got the clutch and a quaifed trans in and what a differance that clutch makes.
We're taking the car to the dyno to tune on April 28th, Lance Chaney and Ransom (sho_sc) will be in to do the tuning.
I'm also thinking I might put on a Zex kit I bought and do a seperate tune for it.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
jay, you are new here, we understand, but you keep posting about your dyno in EVERY thread on the forum, that is unacceptable. Please only post things that pertain to the thread at hand.
adidas_kn
LOWSHO
Houston Texas
I read almost every post awhile back and just now got around to responding. Very nice job on the setup and run. Would love to see that beast run something down on the street.
sho_sc
Georgetown, KY
:salute:
This past weekend I had the opportunity to drive this SHO on the dyno and I can tell you that it is a monster. I have never driven a 3.0L N/A SHO that pulled that hard and that fast. Without knowing, I would have thought I was driving a low boost 3.0L blower SHO. The power curve is very unique; at around 3.5K the engine really wakes up and starts pulling uncommonly hard. You have to remember that nearly everything has been to done to the engine to lighten the rotating assembly and to get it to breathe well at high RPMs. Plus a few “tricks” that has been thrown in the mix.
Now unfortunately, a rod decided to come out and visit us that day. It seems that a rod bolt nut work loose causing undue stress on the other rod bolt, which sheared in half...carnage soon followed. Oddly, the engine idled after venting the crankcase. We were unable to get any useable numbers because we were still in the tuning mode and only running the engine up to 7K RPM. But knowning Ernie, a new motor is in the works .... with even more tricks...
Brett
SHOs before HOs
Minnesnowta
ouch that sucks! Eh, i was surprised to see those numbers but i didnt think it was BS, hopefully the next motor will be more bad ass :rockon:
SeanMc
NoMoSHO
:(. Ernie talked to me about this, the tone of his voice was like he had lost a member of his family. But he said it'll be ready for Bonneville! He was also telling me with the timing backed all the way off, and just messing with the a:f, the thing was putting down ~240wtq.
egroce11
Taylorsville, Ut.
I'm not positive if it was wtg or hp or if I was even looking at the right thing but it was uncorrected numbers. What ever the numbers were, it was sounding great.
Phoenix
SHOHOLIC
QC , Canada
Was that with a nitrous shot? If not , do you think it can be because of a bad A/F ratio?
tool88
pa
bump! because this is awsome
yeah i know its old
sho4life
midwest
So has anyone else built a 300hp n/a sho motor? All it would take is this right?
cams $700
pistions $700
throttle body $100
maf $25
exhaust $500
intake manifold $500
udps $125
bigger valves ?
head work
so about $3000
Phoenix
SHOHOLIC
QC , Canada
cams $700
pistions $700
throttle body $100
maf $25
exhaust $500
udps $125
bigger valves ?
head work
so about $3000
this is just bolt ons , he has engine work and de-stroking.
Im guessing you need to double-to-triple that number to achieve this. And thats only in parts.
bmytych
