My SLO SHO LMS Tuned
Daniel Hill
2017 PP Blue Jeans
Massachusetts
A003DAE8 0297 43BE ACCF D72A23C34433 3660471C FFD0 4827 B2EA CCA71886C3C2 70C1CE56 2EEC 4712 AAB3 2F00B8505A94 im embarrassed to report my 2017 PP,93 octane v11, 3bar, t-stat (only 3,250 miles on odo) ran a paltry 13.3@103mph last night at New England Dragway!
I’ve reached out to Anthony at Livernois via email to see if he can help me troubleshoot what the **** is going on ??
I launched@ 2k, tire psi set to 35, TC off, shifter in S mode.
Maybe I need to pull and check plug gaps... IDK. Research tells me I should be 12.9@105-107 ??
What do u all think?
Thanks
Dan
tpivette89
Middletown, DE
Something is definitely off... even in that DA (which isn't all that bad) you should be faster than that.
My bone stock 2017 PP trapped 103mph in 800ft DA. A tuned car should be significantly faster.
mybigsho
new york
I went thru the same thing.. My first couple outings I was only getting low 13's then I started working on tire pressure and launch techniques... Set tires around 25 to 27lbs shallow stage (just flick on second yellow) bring rpm up to 2000rpm as the lights start bring rpm up a little more and nail it on the last yellow.. From what I see you need to sixty foot better like 183 and better.. That will bring your times a lot closer to the twelves'.. Good luck!!
