Multiple Parts For Sale - Updated 15Nov10 (More/Relisted Parts - Reduced Prices)
Entropy
Hates Pinch Bolts
Tremont, IL
All parts are located near Indianapolis, IN.
Email: shoentropy (AT) yahoo (DOT) com
Updated 15Nov10
All prices are negotiable and do not include shipping (and if you feel like driving -you are more than welcome to pick the parts up). Word to the wise – the better your manners/grammar and the less you come across as a douche – the more likely it is that I will be willing to deal with you. …..and please, if you do not have any interest in the parts – please do not clutter up this thread with your opinions.
I have to put a disclaimer in. I will not sell a part behind your back if you have a genuine desire to get it. Period. That being said – don’t expect because you call ‘dibs’ or ask a question that I will. An e-mail or PM to me stating that you want something and a rough timeline on when you can pay me is a good start. I will do my best to stay on top of all of this but please understand that I work something like 12 hours a day and enjoy nothing more than getting to play with my daughter at the end of the day….cliff note: please don’t expect me to respond 3 minutes after you shoot me a message.
ALL PARTS ARE USED. Within that statement, also read that corrosion in the mid-west is common. All of these parts came out of the first SHO (‘95) I ever fiddled with and throughout its tenure; it was driven snow, rain, or shine. The brakes have about 20k on them. All other aftermarket suspension components have less than 10k on them.
All images are clickable thumbnails.
OEM Gen3 Front Mounts and Bearings. Less than 15k on these parts. Paid $175 for all. Asking $50.
OEM Gen 3 Front Springs. HIM code. Again, Less than 15k on these. Paid $110 for both. Asking $20
Th IMG 0336
24mm Front Sway Bar with TPR bushings. Paid almost $100 for this combo – Asking $40 Sold
26mm Rear Sway Bar with TPR bushings. Paid almost $100 for this combo – Asking $60 Sold
Th IMG 0297
Stock 99' SHO/SLO Wheels and Tires. These were my winter wheels/tires for the Gen3. Clearcoat is not horrible but certainly not perfect. Tires are Bridgestone Potenza RE960AS (All Season - 225/55/16). Best two tires have about 7/32ths-8/32ths left. Worst two have about 4/32ths-5/32ths left. Tires, new, are $230 a piece! Asking $150 for all. Sold
Th IMG 0338
Th IMG 0339
Th IMG 0341
Th IMG 0342
11.6” Rear Brakes, Calipers, and Offset Brackets. To do this right, you need to contact one of the vendors and get a set of rings to make the rotor hub centric (I expect them to be very cheap). Notice again that I did not include the pads. I can part with a set of Hawks if you are willing to throw a bit more money my way. Paid just over $350. Asking $150 now with a barely used set of Hawks. Sold
Th IMG 0292
Catless Y-pipe with Recent O2s. Was on the car when I bought it – no pin leaks known. The welds are a little thick but not horrid. The only corrosion I see is some surface rust on the flanges and welds. Someone told me that this was a SHOShop pipe but I have no clue if the statement holds water. Asking $150. Sold
Th IMG 0282
Th IMG 0283
Ingalls Front Tension Strut with TPR Bushings. For those of you wanting to do the research, you might investigate the folks who have seen failures of these – typically at the point where the rod becomes threaded. I have inspected these and do not see any signs of fatigue. Paid $145 for all – Asking $50 Sold
Stock Rear Tension Strut with TPR Bushings. Paid $75 for these bushings alone (the front one is pricey) – Asking $30 Sold
Th IMG 0300
BMR Adjustable Rear Control Arms. The coating on these failed at the first sign of salt. Blasted and re-painted them when I had the rear apart a while back and they appear to be holding up pretty well. Comes with the spacers for taking up the slack at the rear mounts and the sleeve inserts for each mounting bore (look closely - all 8 are there). Paid $425 for all – Asking $175 Sold
Th IMG 0301
Front Hub Assemblies from a ’95. New bearings pressed in when built. I machined 1/2 inch studs with finer thread to fit the hub because I got tired of breaking the stock ones. Nominal diameter is less than one mm larger but the design is far improved. I am more than happy to discuss why, if you wish, to save the thesis here. No fitment issues with any wheels I have ever had on them. These are what you want to convert your Gen1 to big brakes. Asking $200. Sold
Th IMG 0295
Th IMG 0293
Koni / Uncut Eibach combo. These explain themselves so I will just say that the mounts, bearings, isolator, and bellows were also purchased new. I may consider splitting them up but let me try to sell the assembly for a bit first. OR, find someone who wants the parts you don’t and work something out on the side. I have just under $1100 in these - Asking $700. Sold
Th IMG 0308
13” Front Brakes, PBR Calipers, and Brackets. Note that I did not include the pads but can throw in a set of barely used PBR frictions if you want them (I highly recommend getting a better pad). For those of you wanting to do the research, you might investigate the slightly higher risk slotted rotors have for cracking. I have inspected these and do not see any signs of fatigue. Paid $650 for these. Asking $350. Sold
Th IMG 0306
Braided Stainless Brake Lines. Paid $125 – Asking $75 Sold
Th IMG 0290
SHONut Rear H-brace. The coating on this did not live very well, either. Paid $60 – Asking $35.Sold
Th IMG 0303
17” Team Dynamics – Motorsports. Comes with centercaps if you choose to run with them and the hub centric rings. None are rashed – the two most significant damages shown (very minor, in my opinion). I de-tarred two but two still need done (can’t seem to find the time - note last picture for details...minor, in my mind). DOES NOT come with the tires - it is a recent picture – I just have not had the chance to swing by the tire shop and have them taken off yet. Paid over $700 for these – Asking $400 Sold
Th IMG 0274
Th IMG 0279
Th IMG 0276
Th IMG 0277
Th IMG 0278
MTX Trans. Came out of a 130k car – rebuilt by Anderson Motorsports in Clinton, IL around 85k (before I got the car). Shifts great – no mechanical issues known. As you can see in the pictures – I would put in axle seals. Asking $250. Sold
Th IMG 0286
Th IMG 0285
Thanks for any interest - Jeremiah
:Cheers:
AREA 91
PA SHO SHOP
Area 91
If the sale falls through on the rim's, I'll take them!!!
:wave:
mosho93
Well-Known Member
Wausau, WI
A lot of good stuff! If anybody wants to see what these wheels look like powdercoated black, look in my sig.
I'm eyeing up these 11.6" rears!
Entropy
Hates Pinch Bolts
Tremont, IL
:wave:
Thanks for the interest - you are #4 in line.
Thanks for the kind words and interest. I think you need the rears - shoot me a PM and we will work something out.
Entropy
Hates Pinch Bolts
Tremont, IL
I can not believe that the BMRs have not shown much interest.... Notice updated price - asking the same $250 but now that includes shipping to the continental 48.
Entropy
Hates Pinch Bolts
Tremont, IL
Updated list, did some housekeeping, lowered some prices, and added a couple items.
Entropy
Hates Pinch Bolts
Tremont, IL
Make me an offer on anything not spoken for/gone. Driving from Indy to Des Moines, IA this weekend - can bring anything you want with me except the Gen 3 wheels (but if you are serious, I can entertain driving the truck instead and bringing those too).
Entropy
Hates Pinch Bolts
Tremont, IL
Back from Iowa.... I had an epiphany this weekend due to some folks who seemed to have forgotten how to respond to PM's....especially those where I was willing to give said buyers a bit of time to pay me and time has passed without so much as an excuse as to why. Thus, there have been a couple instances of breaking the 'genuine desire' and 'douche' rules above so some items have gone back out on the market. For those second/third in line who have been patient with before the mentioned folks - thanks...especially those who have already sent me the money less than 24 hours later!
On a happier note - when I said 'make me an offer' above, I meant it. I couple of folks have gotten some stellar deals recently. You could be one of them.
Entropy
Hates Pinch Bolts
Tremont, IL
Last....and probably least. Come get a ragged old 95' shell out of my driveway. Donate $100 to the forum and it's yours. Yes, I have a clean title. I can only think of one thing that I cut (damn rusty A/C lines) - everything else was unbolted and all electronics were unclipped.
Body is straight but it has cancer in the typical spots. Rod shifter, aluminum subframe bushings, solid subframe, and Gen1 non-VAPS rack are still in place. All of the little things like the battery tray, fan, coolant overflow bottle, etc that cam out when I pulled the motor come as well. It also appears that it is going to come with a 24mm front swaybar....
Th IMG 0470 Th IMG 0469 Th IMG 0466
Th IMG 0476 Th IMG 0475 Th IMG 0467
Th IMG 0471Large Th IMG 0472 Th IMG 0474 Th IMG 0473
Interior is complete minus the EATC. Driver's side bolsters shown as they are the worst. Certainly not a show car but I have owned much worse.
Th IMG 0464 Th IMG 0462
Th IMG 0460 Th IMG 0478 Th IMG 0477
I moved it out for easy loading and can build a caster frame under it to roll around on if you desire (but you are paying for the materials....likely $50-75).
Please don't bombard me with hate mail - it's not a parts car (trying to get rid of it whole) and certainly doesn't run so this seems as good of a place as any to put it. Please also read in that statement that I am not looking for an inbox full of 'will you separate this part' types of replies. If no one comes and gets it, I may entertain parting it but may be just as likely to call the local salvage yard so don't bank on it.
