MTX's and differentials for sale..
Erickety
ohio
Rickety Enterprises has now three used MTX's and several differentials for sale. None of the MTX's show any sign of broken roll pins which keep the spider gears in place-pictures available on request.. Differentials
were removed from Customer's MTX's when We installed Quaife limited slip Differentials in Them.. Several of the Differentials have Ring Gears on Them, and speedo gears as well.. Price for the MTX's is $300.00 each.. Differentials are $50.00 each without ring gears, or $75.00 each with Ring Gears.. Shipping can be arranged for additional fees.. We can also disassemble and check for wear and
replace parts and install new seals and reassemble MTX's for an additional fee to be determined by cost of parts replaced.. Rickety Enterprises is still in Business, still repairing/maintaining Sho's,although not many come this Way anymore.. Contact Eric @ Rickety Ent. 330 717 4090 or E-mail, [email protected]...
Erickety
ohio
Roll pins are steel driven into an aluminum differential casting.. Can't weld ferrous to non-ferrous material..But, I have fabricated stainless steel bands which slip over the differential
and are anchored over the spider gear shafts with set screws to keep spider gear shafts in place. We also remove the stock roll pins and replace with stronger ones..
Erickety
ohio
Can you do a V-8 MTX conversion?
We certainly can! We have MTX's and clutch pedal sets, would only need to locate/purchase the appropriate clutch/flywheel setup, and of course the difficult part is coming up with the necessary rod shifter mechanism. Haven't done one of these, but We have the facility and equipment, and know personally what experts We would call to walk Us thru the procedure .. Just noticed Your location is North Carolina ?? An expert at all things SHO is located close to
Atlanta Ga., You might consider having work done closer to Your home State...Eric @ Rickety Enterprises...
shoray
Hinesville,Ga
Have you rebuilt the mtxs or are they just however they were pulled off the car? Thanks
