MTX Transmission Fluid
redsho
Need 4 SPEED
St. Paul, MN, USA
What's a good brand to use. I've been kinda reseaching threads here and faq's on shotimes. I've seen many posts to use ATF's in the 5-speed?! Is that normal or okay? If so, is Redline ATF the preferred fluid to use? Is this pretty easy to do without jacking up car?
Thanks!
-Doua
twr
whoohoo
half-way there, I think.
Yes ATF is what is used in the MTX tranny. You can use any ATF, but a lot of guys around here use Mobile 1 or Redline ATF. I'm currently using 1 quart of Mobile 1 and 2 quarts of B&M Trick Shift synthetic in my quaifed tranny.
redsho
Need 4 SPEED
St. Paul, MN, USA
twr:
I've heard only good things about REDLINE. How many quarts do I need? Is it easy to DIY?
O4SHO
CA
Redline D4 is what you want. You will need to jack up the car and get a mini hand pump to get the old fluid out and put the new in.. you will need 3 quarts of fluid to fill the MTX, Redline will ripe ya about $10 a quart, but it is worth it
drivinhard
Gainesville, GA
There are 2 published specs for the MTX-IV that I've seen, 2.9 qt and 3.1 qt. I've found at the track the vent tends to puke out a little with 3 or more qts in there, so I try to get it just a hair under 3 qts.
