MTX Transaxle Seal
smcallis
Hudson, NH
Ok so I do all this work to replace my rear main seal, carrier gasket, and oil pan gaskets. No more oil leaks. Only now the drivers side transaxle seal is leaking. So I replace the seal and it's still leaking. I suspect I may have buggerd up the metal part a bit putting it in. It was a PITA given the space I had to work with. The seal itself looked ok though. Question is, does any one have a way to get that seal installed straight without f'ing it up while the tranny is in the car? (On the + side I can have the halfshaft out in 15 minutes now.
