MTX oil leak
ShelbyDoug
NY
I've got a fluid leak through the shift linkage input shaft. I know that there is an o ring that is counter sunk into the housing that the rod protrudes through.
To me there is no way to fix this without taking out the transmission, opening the case and removing the shift rod to gain access to replace the o ring?
I tried the Lucas stop leak and it slowed it but it hasn't fixed the problem.
Has anyone of you come up with a solution to repair this o ring without removing the transmission and disassembling it?
If so, I'd appreciate knowing the procedure? Thanks.:)
lincster2
Las Vegas NV.
Try this
Have you ever heard of ATP RESEAL (AT205) Have simlar leaky old piece of ....... was watching the Scotty Kilmer videos on youtube, he says it's great for leaky orings/rubber gaskets, squeeking bushing etc.
It's a little hard to buy............try Amazon.com If you do try it report back with updates. Thanks.
ShelbyDoug
NY
Thanks. I'll try both. Don't think this seal is on the trans? Maybe that's the problem? LOL!
itwonder
VA
Put a wrap of electrical tape around the end of the shaft so it can't nick the seal when you slide it on. Use an appropriate size of PVC fitting/pipe to tap it into place.
lincster2
Las Vegas NV.
pre condition it....
I think that if you coat the new seal with some type of conditioner/ AT fluid it would last longer, plus being easier to install.
AREA 91
PA SHO SHOP
Area 91
Yes, the shift shaft seal is under the rubber boot.
As stated, it can easily be replaced in the car.
Use some fine sand paper/emery cloth to smooth out any burrs on the shaft before installing the new one.
Put a dab of ATF inside the new seal and on the shaft before installing.
