msd ignition
zerg1024
NJ
i was wondering if anyone has done this yet, if anyone has put a msd ignition on their sho and what kind i was thinking of doing this.
GoofSHO
HUGE Dreamer
Vegas
I don't really like MSD....When I was into steet racing years ago...It was't really THAT good...It only had "multiple Spark" at the lower RPM range. It may be different now though.... I prefer Mallory IGN. The Multiple spark" lasted through the whole RPM range.....Again....My Info may be "outdated"....LOL
B
zerg1024
NJ
ok i want one to put in and i need to know what one and all
Minnesho
i was wrong
MinneSHOta
somewhere I read on here that the MSD box wont work for the car??? I cant find the post though....
PROPHET
Well-Known Member
Tonytown, Texas.
Check out the red box where the battery is suppost to be, it's an MSD igntion system I used on my SHO for years.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
MSD DIS-4 works wonders for a boosted applications. I highly recommend it for any UN-natural aspiration. Main reason is the soft touch rev limiter. Factory rev limiter is in the fuel and not the spark. In a boosted car (including nitrous), if you bump the rev limiter, the computer shuts off the fuel injectors in stages. Obviously, shutting the fuel off in a boosted application is a BAD idea. The MSD has a soft touch rev limiter built in. When you bump the rev limit it shuts off spark to the cylinders in a controlled sequence. It doesn't just shut them all off, it rotates the cylinder cancellations to limit the revs. This is much easier on the engine. The MSD is also capacitive discharge and gives you multiple sparks and much more energy. The result is more complete combustion without problems. The MSD DIS-4 sells for $400 and we've got them in stock.
When we do a blower application, we use our SCT Tuning and a MSD unit for ignition. I roll up the rev limiters in the computer, then do the control with the MSD. There is also a retard function. You can pull timing out with the MSD (but you can't advance it) based on RPM. So in our boosted applications, we'll set it to ramp timing out starting at a certain rpm. This too helps the engine stay together.
zerg1024
NJ
ok well i might be getting one in the next month or so and i was wondering if anyone knows how to wire it up. i dont want to screw anything up with the car so.
