moonroof is stuck up and it's raining!!!!!
Rickabod
Representing da U.P.
Brimley, MI
i put the moonroof up and now it won't go back down. anyone know how to manually crank it down?
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
You can manually crank the sunroof closed. But you need an old school window crank, and you must remove the sunroof console.
Pretty self explainatory after that :D
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
Or if your switch broke (which is the usual case) take down the box with the switch in it and take a pliers and turn one of the little nobs on either side of the switch forwards or backwards to shut the moonroof until you can fix it.
autobahnsho
SHO Victim
NY for now, WY for real
Take out the little button in the console so you can see up in it to release the box, if you do.
Isn't there a way to stick a tool in there to manual turn the mechanism?? :confused:
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
Thats what I was trying to explain there... :thumb:
autobahnsho
SHO Victim
I thought there is a way to do it without removing the whole box. But my SHO isn't parked nearby, and it's been awhile since I've messed with the moonroof.
I thought (but still I'm not sure) that if you removed that ugly little round cover that you could turn the mechanism with a screwdriver or socket? :confused:
Of course it'd be a LOT easier once the cover is removed... :thumb:
CheckerSHO
Ford Employee
Acworth, GA
I have seen some overhead consoles with about a 1" diameter access hole to manually crank the sunroof closed...some consoles don't have this hole though :confused: I don't know if it's random or year-related or what. I have a 91 console here that does have it, but i don't think any of my 90's had it, nor my 93 :bonk:
autobahnsho
SHO Victim
AHHHHH- :cool:
Mine has it, I thought all would. Except it is pretty ugly.. :squint:
crystizel
