Moon roof controlls falling apart
Green95SHO
Virginia Beach,VA
hey new to site got a 95 with eddlbrock exhaust and k&nn filter thats about it. anyways my moonroof is falling off any ideals on how to fix it
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
Welcome to the forum! You have found a gold mine of information about your vehicle.
Please go on about what is exactly "falling off". The panel with the button to open/close the moonroof? The glass? The inside covering? The more information you can provide, the better responses (and probably more) you will get.
Now I say good day to you.
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
the plastic piece is falling down? or the switch is falling apart? (your title says controls, but you seem to be talking about the plastic covering which holds the switch, is falling down.
If your talking about this. Take a small flat screwdriver and pop the middle of the light switches down (they switches that covers the map lights in the plastic piece) (they pop out) there are 2 philips screws located behinds the light bulbs...or there should be...check to see if they are there...these are what holds the piece up...that and the metal clips in the rear of the piece. If they are there, unscrew them and slide the whole plastic piece towards the rear of the car...this "unclips" the back portion of the covering. Be careful as there are 2 wiring clips. One for the moonroof switch and one for the map lights...
Hope that helps..
Green95SHO
Virginia Beach,VA
both are falling off but i think i got it from here, thanks for the info but if you have info on the switch itself i would be gratefull
