moisture leak?
93SHO_Guy
Everett, WA
ALmost everytime I go out to my car after it has sat for awhile all the windows have a dew-like coating on them. Is this common in the SHO? Where should I start looking for leaks? Thanks for any help!
ohfosho
ontario SHOwner
ontario, canada
clean your windows well with good quality cleaner...windex is alright, wipe it down good and redo till you cant tell theres a window there! lol also i have heard that wiping dry with newspaper does a great job...the paper absorbs the crap i guess.
93SHO_Guy
Everett, WA
I mean there is a dew on the inside on the windows when I go out to the car in the morning and when I come out to the car after I get off of work. I am thinking that there is a leak in somthing somewhere. Just thought maybe it is a commom problem or someone can point me where to start looking and what to look for. Thanks
JoesSHO
Reality
Did you clean your carpets, seats, or anything else inside recently?
93SHO_Guy
Everett, WA
No, the car has done this since I got it around May. I just moved to Everett, WA recently (around May when I bought the car here) and I don't know if it is the area or what but it has really started to get annoying...I have a squeege in my car to wipe off ast least the windshield on the inside just so I can see out to drive. Thanks for any help.
JoesSHO
Reality
No- The only thing I have seen is if the door strikers loosen up and allow the door to close without fully without sealing... Just a thought- I guess it could also be water leaking/sitting in the trunk and vaporizing through the package tray or something. Dunno! Check the two pits on the sides of the trunk for water, and check the carpets to see if you can find wet spots. Is there a moonroof that may have a bad seal?
