Moaning/Whining When Turning.
Grifter
New Jersey
I just notice that when I make an aggressive left turn there's a whining noise coming from the front end. Kind of screechy, def. high pitched.
Could it be a bad Strut Bearings?
Thanks.
Grifter
New Jersey
I think the best way of describing it would be whining, very high picthed. It's not clunking though.
autobahnsho
SHO Victim
NY for now, WY for real
NotSoSlowSHO:
wheel bearing maybe shrug
I forgot about those- that's probably it. They have a high-pitched grind sound sometimes, because they're grinding at high speed.
Definitely not something you want to have break while you're driving..
Grifter
New Jersey
Would I hear the wheel bearing all the time?
I need to replace my front knuckle, where the sound is coming from, because it's very worn. It allows the ball joint to move around easily. Could that be the noise?
It kind of sounds like the tires are rubbing. I did just put on wider tires, 225. But wouldnt I have read somewhere that they rub?
autobahnsho
SHO Victim
The wheel bearings might or might not rub all the time- you add a lot of side pressure on them while turning, so they could just make noise while turning.
get under the car a little and check if the tires are rubbing. Maybe pull it up onto a curb or something where you can (SAFELY) be under it while someone turns the wheel from side to side to check clearances..
masho95
got Zex?
Chicopee, MA
autobahnsho:
How about putting it up on jackstands? :D
Grifter
New Jersey
I pretty sure the tires arent rubbing. It's only when I turn left and it's at speeds of 20 MPH and faster. I'm pretty sure it's a bearing or maybe even the knuckle(I need a new driver side one)
Grifter
New Jersey
I found out today that I was low on power steering fluid. I filled it up and took it for a drive, no more noise. I'm hoping it's not leaking.
