Kean_SHO
I have an issue that is getting the best of me cause i can't find the issue.
when the engine gets warm it seems like it has a miss. almost like a cylinder is not firing, but i am not sure about that. I just know it has no power and sounds very strange.
I have a CF cowl hood that keeps the engine very cool. on the freeway at 70 MPH the car stays below the first line that marks the NORMAL range and above the blue line on the temp gauge. During this time there are no issues at all. the sho is peppy and sounds fine.
However if i hit traffic and the car starts to get into the middle normal range it will start the crappiness.
I ran the codes got only a VSS and PSP problem code, but already knew i had those issues.
the cylinder balance test came back 9- all fine.
I have not noticed any odd smoke out the exhaust or unexplainable fluid loss. gas milage is consistantly 25-26mpg. I don't see any puddles of fluids when its running or when i leave a parking spot.
I am about to change plug wires (have 5 month old taylor 8mm on now) and inspect the plugs.
anyone have any suggestions of possible issues or tests i can run?
