Electricat
After several hundred dollars and many hours, I have finally worked out all major issues known issues with my SHO!
Only big project left is the rear suspension. But there are several minor things to work out, or check for potential problems, so I have some questions to help me do it:
1. Is the MFS on the SHO the same as the one on the regular Taurus? (After driving around with the wipers and washer going at random moments, I have decided that MF doesn't stand for "multi-function" !
2. Is there a method to test the MFS using only resistance testing? (I would like to check a junkyard unit before I buy it).
3. I seem to have an oil leak coming from behind the oil cooler. How is the cooler attached and sealed to the block?
4. At WOT, my ATX shifts 1-2 @ 6500rpm, and 2-3 @ 6000rpm. Are these the normal shift points?
5. I would like to make my own aluminum subframe bushings and subframe connectors. I built SFC's for the '95 Mustang I had before the SHO, and loved the difference they made! I have access to a lathe, so making the bushings would be no problem. I don't thing the prices that people sell these items at are unreasonable, it's just that I can do it myself for much less. The question is...does anyone have dimensions/plans for these items, free or for a small fee?
6. With an aftermarket head unit, will the remote buttons for the radio still function?
Thanks in advance for help with any of these questions!
Only big project left is the rear suspension. But there are several minor things to work out, or check for potential problems, so I have some questions to help me do it:1. Is the MFS on the SHO the same as the one on the regular Taurus? (After driving around with the wipers and washer going at random moments, I have decided that MF doesn't stand for "multi-function" !
