Mint 93ATX Original Owner $3000 OBO***SOLD***
Green93ATX
Connecticut
Having no end of trouble listing my add here. Much abbreviated version: Super clean, all original, never seen snow, rarely seen rain, always garaged, everything works, runs and drives excellent, no dents, no rust, no accidents, original paint, 160K, all maintenance up to date. Never had a check engine light or any real problems. Call my cell (860)798-3524 or respoind here for complete details. Location Tolland CT. Retired Civil Engineer downsizing.
I would drive this car across the country right now without any worries. This car only needs a new home. One of the best examples left.
See Pictures below
Finally can access this page with my wife's laptop. Only had one real issue with this car. Last summer the alt was giving low voltage and I had strange electrical issues. Replaced alt with reman Motorcraft and also replaced battery cables and put in a used computer and all is well now. At the same time put in new plugs, wires and replaced valve cover gaskets. Inside of engine like new, all clearences within spec. Also changed thermostat and all fluids (brake, antifreeze, powersteering) and put in new fuel filter. Also new tires and front brakes. Car is in excellent running condition and drives great. Would like to see it have a new home with someone who knows these cars.
Irish Pride
Irish Inside
MusicCityUSA
Copy the
95GOOSE
Mass/SoCal
Very nice. Don't see many cars out of Connecticut in this condition.
GLWS,
Bill
Green93ATX
Connecticut
At 60K, all clearances within spec. Flipped the shims over and adjusted to be in middle of range. Changed all hoses and clamps with the kit from FPS. At 83K changed water pump, front main seal and crankshaft position sensor(still clean) and put on new timing belt. At 155 K checked all clearances and within spec. Inside of engine like new. Inspected all lobes on cams and all looked like new - no sign of wear. New valve cover gaskets, plugs, wires, fuel filter, thermostat and all fluids changed. I have been religious about changing oil and it shows. Cleaned the intake including ports for IAB and EGR. Running great now.
shobroooo
