Zap
I am in the midst of doing my Front 60k (mainly due to oil leaking on the front cat). I was making excellent progress until I met a rounded off bolt on the middle timing cover. It spun with the 8mm socket, so I tried a standard near that size. That worked for a little bit and got the bolt to start spinning, I think... However, now I can't even get that socket to turn the bolt
. It appears that someone felt the need to reinstall a bad bolt into this cover.
So, the cover moves a little bit since the bolt has partially made it out, but I can't for the life of me figure out any other way to get it the rest of the way out. On a positive note, besides this fiasco, I've had nothing but good feelings about the rest of the job. The crank bolt, keyway, and timing gear look to be in excellent shape. Also, it looks like there is at least one leak from the rear intake cam seal, so hopefully I have located my problem.
So, the real problem at this point is that I need to figure out how to get this blasted bolt out so I can remove the middle timing cover and continue with my 60k. Additionally, I need to know what exactly to pick up from the hardware store (we've got Home Depot, Lowes, and a DoItBest store around here) to properly install my new front main and cam seals. Also, I'm curious to know if I should be using Loctite on the cam gear bolts and the crank bolt when I get to the reassembly stage. I know I've seen it suggested, and if it will help keep them secure, I'd be glad to throw some on there.
I'm also not very thrilled to find out I'm missing timing cover bolts:
Upper - Have 5 shorter and 2 longer bolts, missing two bolts
Middle - Left side bolt missing, need both to be replaced due to rounded right
Lower - Upper left bolt missing
It works, but needless to say I'd rather have all of the proper bolts. If anyone happens to have some spares, please send me a PM.
Thanks for the help, and BTW SHOPhoenixProject ROCKS!
I've been using a printed out copy of the guide (actually without pictures) and I've only needed to come reference the photos a few times, which clarified what I was looking for very well. Hopefully I can get my SHO back on the road soon! :****:
So, the cover moves a little bit since the bolt has partially made it out, but I can't for the life of me figure out any other way to get it the rest of the way out. On a positive note, besides this fiasco, I've had nothing but good feelings about the rest of the job. The crank bolt, keyway, and timing gear look to be in excellent shape. Also, it looks like there is at least one leak from the rear intake cam seal, so hopefully I have located my problem.So, the real problem at this point is that I need to figure out how to get this blasted bolt out so I can remove the middle timing cover and continue with my 60k. Additionally, I need to know what exactly to pick up from the hardware store (we've got Home Depot, Lowes, and a DoItBest store around here) to properly install my new front main and cam seals. Also, I'm curious to know if I should be using Loctite on the cam gear bolts and the crank bolt when I get to the reassembly stage. I know I've seen it suggested, and if it will help keep them secure, I'd be glad to throw some on there.
I actually wasn't going to change the W/P due to trying to keep this as low budget as possible, but I'm going to order one now. I don't want to have to rip all of this stuff out again!
