Sgtmeatsauce1
2013 SHO +pp
Subscribe
Any new thoughts on the coil-overs? Did you soften the dampers any more? Can the ride be made to be softer/smoother than stock? I'm wanting to do this to my MKS and wouldn't mind a touch smoother ride as I spend most of my time on the highway. I also want to lower it a little, but not as low as most springs provide and this is the only real option worth it IMO due to the adjustability. Also, where are the pictures of how your car sits![]()
Love the look, LOVE the colorNice review of results. The coilovers ARE a commitment. Now if you got the SHO corner balanced, you could go autoXing for more thrills than canyon carving LOL.
God Speeds on MONO SS coil overs on my 2010 are working well now that I have them tuned. The come with 6kg/mm front springs and 14kg/mm rear springs. Ride height is a one finger gap between fender and tire. Street driving was bottoming too much on the fronts. I am also running 275 40 20's, which are heavier tires. So, got some 10kg/mm 200mm long springs from God Speed Project and got them for 100 bucks. Made a HUGE improvement on ride, handling and no more bottoming. Just an FYI to save someone else the torture of bottoming out. Poly Urethane sub frame bushings also made the car hold the line way better at high speed too. Whiteline sells a Mustang set that'll fit the SHO pretty well.Soooooooo....
After a 4 day journey installing the Megan coilovers, PowerStop drilled/slotted rotors, AND replacing the front hub/bearings; I finally finished. While it's definitely NOT a job for the timid, it really is within the ability of those who are mechanically inclined with decent tools. Initial test drive was IMPRESSIVE! The car now corners nearly flat instead of the rather pronounced body roll when cornering. I set damping right in the middle (level 8) and now feel every little pebble LOL. Might be setting a little softer. Tomorrow will tweak the ride height, but was pleasantly surprised that my best guess turned out to be almost right where I wanted! Go figure. Goes in for alignment tomorrow. The PowerStops are incredible. I'll be posting a full installation documentation with pics in the next few days.
