Maximum tire size on a 17"x9" rim?
jdh00
Westbrook, Maine
Will 245/40/17 tires rub? I know they'll fit on the rim, so the subject is misleading.
92MTX, Dynomax exhaust, Coneless, Conical filter, 17x9" Cobra R's, 235/45/17 Dunlops/Pirellis
DeaconBlue
Cleveland, Ohio
I have 245/45-17 tires on 17 x 8.0" rims with a 40mm offset and no rubbing, but they are real close to the rear strut towers. And no I didn't have to trim any sheet metal either.
95 MTX
with a few mods
94shoboy
south shore, mass, usa
i wasn't aware that a 9" wide rim would fit. BUT i had 17x7.5 mille miglias with 245s and they rubbed the strut tower so i put spacers on and they rubbed the fender. i cut the fender and they rubbed slightly still, so it all comes down to the back spacing. to fit a 245 it has to be PERFECT
jdh00
Westbrook, Maine
Yeah, i ran 9" rims all last summer with spacers. With three people in back, the 235's rubber the fender well... So that would make sense that a 245 would rub.
DeaconBlue
Cleveland, Ohio
If the 235 or 245 tires are too close to the rear strut towers and you still have room on the fender lip side, you can make a set of wheel spacers out of a set of old rear disc brake rotors. Just cut the top of the hat of the rotor (the part off the rotor with the lug holes) with a cutting tool and you have a spacer that's about 2mm thick, just the ticket to keep those wide tires off the rear struts.
95 MTX
with a few mods
