master cylinder
bigpappy
Mobile, Alabama
I've got a bad master cylinder. Where brakes are concerned, I feel better having a mechanic doing it, so all I'm trying to find out is if a 93ATX master cylinder would work in my 94ATX. Did all the 93-95 atx have ABS?
Thanks,
John
jasonty
Abilene, Texas
Yes, SHO's came standard with ABS after 89. The ATX master cylinder will work fine... I'd have it installed by a mechanic though, because if you don't know how to bleed a master cylinder, you'll be ripping your hair out for hours trying to figure out why nothing but air comes out of the bleeder valves on the calipers. There is a special kit used to bench bleed master cylinders. It's not complicated, but if you don't have the kit, you're kinda screwed. Good luck!
