Mark viii maf conversion, at what point?
NovaSS
Project MINIGUN
I have a chip thats going to sho source for a burn job, I have the option of using the stock MAF or going to the Mark VIII.
My question is at what point will you see any differance on a N/A SHO ?
my engine
1994 3.0 bored to 3.2
new gaskets seals rings and seals
69 MM throttle body
oversized valves, bronze guide, 3 angle valve work
BBB, ported runners, big bore air horns
+20 cams
custom headers, aftermarket cats, free flowing dual exhaust.
2400 lb car
Ishodu
I found the 80 mm lightning maf to read much more accurate in the higher rpm band than the stocker. I also have notice a much better throttle response. I would go for one If I were you.
illSHOyou
Troy, MO
my engine
69 MM throttle body
+20 cams
2400 lb car
Can't believe you don't have one on already....? That 80mm MAF is going to do wonders as a supporting mod for your list, without it would hinder the rest of your mods.
stangeater
Farm Boy
Definantly get that thing tuned and installed! Right now your stock Maf is a restriction in a way.
SHOspazz92
Banned
Triad Area, North Carolina.
On a Cammed/Bolt on engine it's definently going to make a difference. I had a aftermarket 75mm MAF on my SHO, I was not happy with the tune at all on it as down low the car ran like garbage. However up top the car was pulled great.
When I switched back to a stock MAF, The car ran WAY better (A LOT more TQ across the powerband) however I noticed my top end had taken a hit.
I imagine, When I eventually get my car tuned with a 80mm MAF, I'ts going to be a lot better across the board. The old MAF I had (Pro-M) was just not a very good unit for my car.
FWIW, I have a 3.0 With +20's, BBB/EH Intake, Y-Pipe and Custom catback.
-Sam
Sho Amo
SmkTyresntDrugs
Olney, Md
it helps big time. it took 2 tenths off my 1/4 time when coupled with a new intake. it also added 2 mph to my trap speed.
NovaSS
Project MINIGUN
found me a nice 1995 80mm Mark VIII MAF, time to send the chip to be burned:)
Sho Amo
SmkTyresntDrugs
Olney, Md
sweet. that means you doint have to cut and splice your maf connector it should plug right in.
NovaSS
Project MINIGUN
summit has one pretty cheap, plus I need to make an order so Ill add it on.
AREA 91
PA SHO SHOP
Area 91
my engine
69 MM throttle body
+20 cams
2400 lb car
Time to upgrade your MAF!!!;)
