Map And Pcm
MadMiike
DULUTH MN
Where is the Map sensor? Is it under and behind the Intake? Also where do I find a Pcm for a 94 Mtx :shrug:
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
It doesnt have a MAP. IT has a MAF and Baro sensor. The PCM is located on the firewall, passenger side, behind glovebox. The Baro is the black sensor about in the middle of the firewall.
MadMiike
DULUTH MN
I was asking where I can find a New Or Good used Pcm? If the Pcm was bad would the car still run? What exactly does the Baro do?
MadMiike
DULUTH MN
Hmm I must be blind all I see Is Quote, Multi Quote this message and Quick reply. That is the bottom right isn't it?
It should be to the right of Q-reply. NOt sure why you don't see it on your screen. Look at another post and see if it's available to you there. Maybe theres a minimum post count or time of membership until it pops up for you. Try asking a moderator. I'm curious myself. ...and you hit the thanks button in the post of the person you are thanking, not your own post.
