Manifold Intake
sp0ck
Ohio
My Check Engine Light is on and the error given is....
Manifold Intake Stuck Open (Bank 1) Can someone please explain what causes this.
What can I do to fix it? Any opinion or suggestion on this would be appreciated!!
Again I want to thank anyone who takes the time to read my problems and more so the people who try to help me!! This car rocks by the way!! 97 SHO v8 with 139,000 and it runs great!!!
JCC
SHOTIME
Giver of life
Boston Ma.
I would have to say check the secondaries. If it wasnt getting vaccum it wouldnt close and they would be open all the time.
To test, leave the car running. Stand over the car and use the throttle body to rev the motor past 4K and watch to see if the post on the secondaries move. if they do not. they arnt getting vaccum.
sp0ck
Ohio
reply
P1518 Manifold runner stuck open (bank 1)
P1744 TCC? <= new error, I need that one explained also.. with possible ways of fixing them... Any and all info will be appriciated!!
Tim Rice
Lynchburg, VA
well the PCM thinks the IMRC is stuck open on the lower intake manifold. Which may be the case if the butterflies are gummed/carboned up (mine were extremely nasty when I took it apart to do the cam weld after only 33k miles).
Take the engine appearence cover off and run the engine up to about 3k rpms and let it off quickly, you should see the IMRC control cable open and close briefly ( the IMRC control is that small square box on the front cam cover) make sure the electricial connection to it is secure also. the control cable runs up under the throttle body and actuates the butterflies on the lower intake manifold.
Not sure how many miles you have on the unit but a thorough intake cleaning (upper/lower and surge tank) in probably in order. if they arent gummed up my guess is the IMRC controller is failing for some reason.
sp0ck
Ohio
This car has currently 139K on and it runs great. I love it and I anything I can do to keep it running like she is what I want.
Thanks for the info and from what I read, this doesn't sound hard to fix or manualy check either.... Any other suggestions are welcomed.. Have a good day..
JCC
