major misfire
95IVSHO
1995 SHO 3.2L ATX
155,000miles
when car is cold i start driving and after a little while it starts to mis alittle here and there and then gets progressively worse. it does it on acceleration the worst, and it does it at idle not enough to **** the car though. there are no codes
95IVSHO
im sure there is oil in the wells. i fixed it at about 90000miles. and its back again. i was leanin towards the that as being the problem. looks like ill be going for plugs and wires again, thanks.
bubba
ATX Connoisseur
Fort Wayne, Indiana
Has the car ever had on on 60K? The plugs could be fouling out with the oil in wells. Good luck.
95IVSHO
im not sure if it had ever gotten its 60k done on it. i did install a newwater pump, timing belt plus tensioner, cam sensor, o2s with the plugs and wires at 90k. and basically everything else since then.
bubba
ATX Connoisseur
Fort Wayne, Indiana
IAT could be to. Most likely it's never had one. You already have half of it done. I would do the other half.
95IVSHO
IAT has been done. the gaskets and plugs are on the way, debating on wires, accel again, or taylor or ford
