Lug nuts on aftermarket wheels
814SHO
I just ordered a set of wheels and was wondering if I had to run aftermarket lug nuts for them to fit?and if so what are some recommendations
TDS-MN
Minneapolis, MN
Hmm, wheels i ordered from Tire Rack came with the necessary lug nuts, centering rings, etc. I have not bought from other vendors to know if they throw in all of the little things or not, though.
SHOnUup4
SE MI
Do not buy the cheap ones from local auto parts store.
814SHO
But do I have to purchase different lug nuts though I currently have the premium wheels on if that makes a difference.
SHOnUup4
SE MI
Will depend on the seating point, if they are concaved the same or not...
OmaHahn
Omaha
Please share! What wheels, tires, etc. Pics??
2011TAURUSSEL
2014 SHO LMS Stage 1 V10
DFW Metroplex, USA
If you purchased from Tire Rack then you should have everything required. I am still on OEM lug nuts but the wheels came with another set.
And +2 on photos of new wheels.
SilverSH0
+1 to this. On the lug nuts there is a beveled angle on the nut that mates to the wheel. The wheel has the same beveled angle on it so the nut seats properly to the wheel. If the nuts for the same wheel have the same angle, you should be able to reuse what you have. If it's different, you'll need new nuts.
gary4n
Fl
If you want to use aftermarket ones, go with McGards. They are warrantied not to rust and chip.
bmytych
