Deaks2
Hi there,
This spring plan on getting a 73mm MAF, SHOShop Y-Pipe and exhaust, in addition to some suspension and brake mods.
My question is I have read up on LPM's, and from what I can see they can do quite a bit of good. I have also read about an 8000-rpm revlimit with these modules. Do you guys forsee any problems with 8000-rpm and the otherwise Ford OEM-equivalent belt-driven accessories, most importantly being the water pump. I remember reading how the Chevy LT-1's water pump would cavitate above 4500-rpm, I would certainly not want that to happen in the SHO...
Is there any power to be found in having an 8000-rpm revlimit? I know the SHO has a rev-happy engine, but from what I have seen on dyno curves the torque and hp numbers start dropping well before the existing 7300-rpm revlimit.
