Lowering Spring Questions....
KentuckySHOoff
Bardstown,KY,
ok i have spent the last hour reading things on the search, so do eibach and intrac springs lower the car or not. i have some hella wheel gap on the front but i believe that the majority of it is caused from the sagging rear. what do you all think?
SnoSho
Circle Pines, MN, USA
In a perfect world they lower, Intrax more so. In your case it might raise it if your springs are bad. For sure the rear will come up and then settle back down abit if you do have a real problem in the rear.
Ishodu
Yes they do lower. My Eibachs lowered the front only about 3/4 inch I used the Police mounts that are a little thicker then some others. My back did come up almost 1" because they were sagging so bad. But when I was comparing them to other shos yesterday at the V6 challenge my car was a little lower all around.
3.8Lwagon
Shaggen Wagon
with my wagon the eibachs lowered the **** out of it. especaly in the rear, but i didn't have any saging in the rear
SHO5
ADDICTED
Fond du Lac, WI
well i got the intrax all around and it looks awesome. The only problem with it though is sometimes going over bumps the suspesion bottoms out in the front because they are progressive rate. The ride like a rock but do improve handling. Does anyone have intrax springs that aren't progressive rate? They would work a lot better
BlownByU
Guest
New York
Intrax only makes progressive springs, at least for the SHO. The only linear springs that I am aware of were made by SHO SHOP and they looked real good but they don't make them anymore. Even the eibachs are progressive
