Yipeekayea
- Joined
- Jun 24, 2016
- Messages
- 141
- Reaction score
- 83
I used the search button, lets get that out of the way. Long story short, recently I noticed the car making clicking sounds going over bumps...........that evolved into the car making weird unsettling squeaking noises while turning the steering wheel. I can't 100% nail this problem down to the lower ball join, but when I got under the car, I noticed a bunch of residue on the inside of the front passenger wheel, and the lower ball joint had a torn boot. I stuck my finger in there and it appears to be dry. I'm guessing that means the lower ball joint is messed up and that's where these weird noises are coming from? Is this common on a car with this low miles? So the only replacement I could find was a motorcraft part from RockAuto, anybody aware of an upgrade from the factory junk? Is it safe to assume this problem is from the lower ball joint being dry? I was so paranoid the wheel was just gonna fall off I took side streets home from work and didn't go over 20 mph.
