Of course this acts up the week before the convention.
OK, so my 95 MTX was having some cooling issues. Had a hose that didn't get tightened down on water pump replacement, and my cap was only holding 12 psi instead of the 15 or 16 psi rating. Figured I had it nailed when I replaced the cap with a new, tested Ford cap, and tightened up the hose.
Car has been fine the last few weeks, but driven on max AC because of the heat wave (fan goes to high on this setting and stays there IIRC). Today it was less than 80 and low humidity, so I drove on vent the whole way home. One bout of stop and go traffic.
Get into my town and the needle is up to N in NORMAL, and the engine is running a little rough. Pull over and the fan kicks on as I open the hood (on low), The fan runs for a minute or so and then kicks off, with the needle barely down below O. Drove it home trying to keep airflow over the radiator, and in the driveway the same behavior.
This is way higher than historic levels (I am the original owner) - usually I get fan on at the M and fan off at the A. Is this a CCRM relay problem? If so I can not read the code as my module has a thick black cushion of some kind adhered onto it from the factory. Is there a specific coolant temp sensor that EEC looks at to decide fan on/off? The one next to the T stat?
Or is it the close proximity of the fan motor to the exhaust manifold as a consequence of the two row rad, plus subframe slid forward?
Any insights gratefully appreciated.
