low fuel pressure
withku
Phx, AZ
So i’m having issues with fuel supply, it’s something i messed up during rebuild. Turns over for 5 seconds before starting and sometimes idles rough. Bogs down if i hit the gas.
For some reason fuel rail pressure isn’t going above ~75 psi. Everything is plugged in.
Getting code P0087, and a fuel pump fault / fuel rail pressure control fault on forscan.
I doubt my HPFP magically died over the last couple months. I’ve swapped all injectors. Any ideas on what the issue could be?
here’s some forscan logs
GotGrip?
Conversation Ruiner
Minnesota
Just went through this, my XDI-35 died. Swapped stock pump on and switched tune, runs just fine. Same code as you.
stripSHO
Idiot Savant
Detroit
This is hopefully a stupid question but... did you reinstall your cams in the same heads they came out of?
