Lost Tappet Compressor, Can I Use Something Else?
Status
Not open for further replies.
BlackOnBlackATX
Dutchess County, NY
OK i seemed to have misplaced my tappet compressor and i need to get to my valve lash *today*. is there something else i can use in its place? thanks guys.
RStalveyARFF
too many shos
Georgetown, MA
Nope. Head down to the dealer and see if they hae the 3.0/3.2 engine service kit, and see if they'll let you buy it out of th kit.
BlackOnBlackATX
Dutchess County, NY
good enough, i realized i cant turn the cams without pulling the timing belt off anyway so since theres not much daylight left im going to call it quits and reassemble here. thanks.
Yamaha V6
SHO Enthusiast
Rhode Island
Yes you can... 19mm socket on the crank bolt with a breaker bar. Works wonders. :)
It's a LOT easier with the 1 1/16" (27mm?) wrench on the cam itself IF you remove the timing belt (too much stress with the belt on).
shojuan
sunny San Juan Bautista,
Yamaha V6:
Hehe, that's what a 3 foot long PVC pipe cheater on a ratchet on the 19mm crank bolt is for. Takes only one arm leaving the other arm free to hold a beer! thumbs_u
<small>[ March 28, 2003, 05:13 PM: Message edited by: shojuan ]</small>
Minnesho
i was wrong
MinneSHOta
even easier is to leave the drivers side wheel on the ground, jack up the pass side, put the car in 5th gear and turn the pass tire by hand.
Mr Anonymous
Tire Wall
Two and half years after the fact, I can't fathom what you were hoping to add...
Status
