masho95
got Zex?
My clutch pedal doesn't adjust with 10 lbs. of force up on the pedal. How do you manually tension the cable? Something about lifting up and the pedal and pushing something towards the firewall? I lifted up on the pedal and pushed back on the plastic piece that the clutch cable is mounted to. Is that the correct piece? If so I was able to push it pretty much all the way back with no clicks or other noises. Does this indicate a disfunctional clutch adjuster? Also the TOB shaft has a bit of play back and forth AND up and down with the car running. There is almost no play with the car off.
