loose rod shifter
sho4life
midwest
i have solid engine mounts, new front boss brace bushings. its tight to the frame but it clunks. do i need a new replacement ball inside the black box? what else could it be?
AREA 91
PA SHO SHOP
Area 91
Pull the entire shift linkage out of the car so you can inspect it.
If there is play inside the "black box", you can get a replacement from: www.shonutperformance.com
If the play is at the clevis, you can contact jose (the inventor of the SHOrt shifter) on the forum. He has a kit to fix the problem. with a little rigging, you can also fix it yourself with a couple of washers, bushings, and a bolt/nut.
sho4life
midwest
i think it is just from the exhaust rubbing, i'll inspect soon , more important issues right now
K-Dawg
Treasure Coast, FL
SHOSource sells one bushing, SHONut sells the ball and socket, and SHOForum member rktmn sells his bushing and clevis pin.
