Looking for good write-up on replacing cam sensor on 96 SHO?
5.0stang
Just like the title says:)
The pictures were down over at v8sho.com...
Where is a place to get one new for cheap? Any auto (autozone?) retailers and part numbers?
Thanks!
naval-avi8or
Chesapeake, VA
Thanks!
Camshaft Position (CMP) Sensor
Removal
1. Disconnect battery ground cable (14301). Refer to «Section 14-01».
2. Disconnect the engine control sensor wiring (12A581) from the camshaft position sensor (CMP sensor) (6B288) at the connector.
3. Remove camshaft position sensor retaining bolt from the LH cylinder head (6049).
Installation
1. Make sure camshaft position sensor mounting surface is clean. Make sure that the camshaft position sensor O-ring is in proper location on camshaft position sensor.
2. CAUTION: Do not overtighten camshaft position sensor retaining bolt or damage to the camshaft position sensor may occur.
Install camshaft position sensor retaining bolt. Tighten bolt to 8-12 N-m (71-106 lb-in).
3. Connect the engine control sensor wiring to the camshaft position sensor wiring connector.
4. Connect battery ground cable. Refer to
KILLA
SHO enough
COLORADO
If your talking about the cam position sensor, i just replaced mine today.
However, it didnt fix my problem, so i assume its good. Since i only paid $15 for it i didnt plan on putting the old one back in and returning it. If you want, ill give you my old one and send it your way free of charge. ;)
It might not be new, but its easy to change if you ever need to do it again (i think it took me 60-90 seconds). I dont see why it wouldnt last a fair amount of time.
