A poor ground connection can cause conditions similar to those that you mention. Check for the proper connection of the braided ground strap to the upper bolt on the passenger side rear intake bracket. Ensure both electrical connectors to the DIS are secure. A "wiggle test" of these connectors is a good check that they are not a source of a discontinuity. If you have a painted or powdercoated intake, you may need to clean to bare metal the ground connections at the DIS module and the bolt flanges that secure the balance (crossover) tube to the front and rear intake plenums. These checks are a first step and are much cheaper than a replacement DIS.
