STRider
A couple of weeks ago I replaced front rotors and pads, rear rotors, pads, calipers, caliper brackets, slider pins and hoses and I flushed the brake fluid with Ford heavy duty brake fluid.
To flush the braking system, I borrowed a bleeder from a mechanic friend. You fill a reservoir with brake fluid and attach it to the master cylinder. Connect the bleeder to an air compressor, attach the hose to the bleeder screw, open the screw, press a button on the bleeder and it draws the fluid through the system. I used 3 12 ounce bottles doing the right rear to make sure I flushed out all of the old fluid. Then I used on 12 ounce bottle on LF, LR and RF.
After a week of taking it easy on the brakes, I seasoned the rotors last Saturday by braking normally from 65 to a stop 5 times to heat up the rotors, then 65 to 5 five times using moderate pressure (maybe 50% pedal travel), drive for 5-10 minutes to cool, then 65 to 5 five times using more effort (maybe 75% pedal travel), cool for 5-10 minutes, then park and let sit overnight. Then I repeated this on Sunday.
This Saturday I attempted to bed the pads using the same procedure as seasoning the rotors. After warming up the brakes, I was attempting to use the brakes as hard as possible without locking them up and activating the ABS system. The only problem is I used all the brake pedal travel and the brakes wouldn't lock up. Since I installed Performance Friction Carbon Metallic pads, I thought I might have to repeat this procedure again to properly bed the pads. So I did on Sunday and got the same results.
So, are the brakes on a 95 Sho so inadequate that it is impossible to lock them up on dry pavement, or is something else possibly wrong? Do I need to bleed/flush the brakes a different way since I have ABS?
