armerdan
armerdan
So here is my long sad story........
It all began 2 weeks ago when I was headed back from lunch.......
I went to stop and the brakes went straight to the floor. So I'm thinking ok master cylinder, it wasn't every time just about every 5-6th time they would just go straight to the floor with almost no braking at all.
So I replaced the master cylinder no problem at all, easiest thing in the world.
I took it out for a spin and it seemed fine till I tried out the ABS, now sure enough they don't go to the floor at all, they stop really well.....
Too well...
So well the car won't go, even when I want it to.
So I'm thinking ok, the fluid was a little (a lot) less clear then it should be, maybe there is some trash in the lines that's messing it up eh? So I completely bleed the system out replacing the fluid as I go with new fluid forcing the old stuff out with the new stuff, and I toss some SS lines in for good measure $104.00 from Summit shipped.
It drove fine until I decided to make her skid a little bit to test the ABS, They locked up good again.
Disconnecting the ABS makes no difference at all.
The only thing that works is letting some pressure out at the bleeder valve, and then it only works for a while and thy slowly lock up again as I use the brakes more, (or they quickly lock up if I slam on the brakes)
So my question is this.
Is there anything mechanical in the ABS system that could be letting the fluid only flow one way? Or could I have a bad proportioning valve? Or did I maybe just get a bad MC?
What do you think?
Too well...
What do you think?
